I am creating my own Season 5 of '24'.
I have high def service and I am capturing from my DVR to my card via svideo in AVI format then to Mpeg2.
I am curious as to how the commercial '24' box sets fit four episodes per disc plus the pertinent Dolby Digital files. It seems that I have to create the mpeg2 files at a bitrate of around 6000 to fit four episodes on a dual layer disc. But I am wary of the video quality decrease as compared to a 9000kbps mpeg file.
I realize that when I edit out the commercials each episode will be about 48 minutes long - as opposed to 60 minutes and that in itself will reduce space requirements somewhat. Also, my audio will also be 2 channel not the 5.1 on the commercial dvds. Nevertheless, I am still concerned about appropriate bitrates etc etc.
Should I create each episode with a specific target bitrate or create the episodes at max bitrate and use DVDShrink to compress the entire project?
Any advice would be appreciated... thanks.
NEC 3500AG - Firmware 2.TG
LiteOn 16P9S - Firmware FS09
Taiyo Yuden 8X, FujiFilm 8X YUDEN000T02, Phillips 8X CMC MAG-E01-000.
DVDDecrypter, DVDShrink, DVDFab, Nero 7
Hauppage WinTV PVR 150
Dscaler, TMPGEnc Plus/Author, Canopus ProCoder, CCE. -
They will be encode using a variable bitrate, with an average of around 6000kbps (combined audio + video). With VBR, the talking heads scenes will use a lower bitrate, preserving some extra bitrate for the action scenes. 2 pass vbr should give you pretty good quality. You won't match the official release as you don't have the quality of source that they are drawing from, nor the hardware they have on hand for transfers.
Best quality is always obtained by encoding to the correct bitrate, not going high then transcoding down. Transcoding will degrade quality a lot more than re-encoding.Read my blog here.
Convert Multi-episode DVD to 1 avi file
By cfs6254 in forum Video ConversionReplies: 2Last Post: 16th Jan 2011, 03:26 -
Ripping a multi-episode DVD
By scoopyx in forum Newbie / General discussionsReplies: 5Last Post: 21st Dec 2009, 23:55 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 12:42 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 17:39 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 10:32
