OK, I have a DVD I'm backing up, the original DVD I burned to was of poor quality.
I successfully copied all 4 VOB files to my hard drive. Problem is I cannot reburn them to a new DVD.
One of the 4 VOB files seems to have issues.
I can play the VOB file with Nero ShowTime but it won't load to programs like TMPGEnc DVD Author. I also cannot load the DVD folder to DVD Shrink which I normally use for burning new DVDSs.
I tried to convert the VOB file to MPEG2 with TMPGEnc.exe but it ended up making a file that was mostly black screen and no audio.
I nave Nero but have never used it directly for a burn, I always use DVDShrink.
This is NOT a commerical DVD so there are no problems with macrovision protection or anything like that.
I can watch the problem VOB without issue using Nero ShowTime but can't seem to burn it. Any ideas? I wish Nero ShowTime had a "save file" feature.
Use FixVTS.
If you want a 1:1 copy use DVDDecrypter ISO Read->ISO Write.If DVDDecrypter chokes on a VOB then try DVDFab Decrypter and Nero to burn.
2.94 gb VOB file to DVD-R issues
By DirtBikeMike in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2010, 12:01 -
Conversion issues with with 1. vob-file of a ripped dvd
By NSmooch in forum Video ConversionReplies: 5Last Post: 8th Jan 2010, 02:55 -
Very Strange problem with a Vob file
By nerys in forum DVD RippingReplies: 7Last Post: 11th Nov 2008, 17:33 -
VOB file size problem
By mb1512 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2008, 16:58 -
Problem with .dv file that I converted from .vob for iDVD
By eric56 in forum MacReplies: 7Last Post: 9th Jul 2007, 04:25
