I’ve been running the Trial version of PowerProducer 3 (v3.00.921) with some great capture results from my AVerMedia DVD EZMaker USB2.0 I decided to upgrade to the full version – PowerProducer 3 Deluxe (PAL) but since the upgrade the full version wont give a proper capture picture (green and black segmented upside down picture).
I believe the problem is related to the automatic recognition system that PowerProducer uses for the Full version. On the trial it sees my EZMaker as a webcam but on the upgrade as a VCR – there is no way that I know to change this and I’m tiring of trying to get a fix out of Cyberlink’s tech support section.
PowerProducer is by far the best capture software and I would like to use it. Does anybody know where I can get an earlier version of PowerProducer 3 (think v2 may do the same job for me). I intend to ask Cyberlink but just thought I’d post here for some advice.
Results 1 to 1 of 1
Audio Codec Not Working in PowerProducer
By travbickle in forum Software PlayingReplies: 21Last Post: 5th Dec 2011, 14:28 -
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 09:34 -
PowerProducer - edit dvd menu template
By kj1983 in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2008, 19:37 -
Alternatives to PowerProducer?
By Nilfennasion in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jul 2007, 11:32 -
Using Cyberlink PowerProducer... no video during authoring
By 27am_dot_com in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 20:55
