Hi
I would like to convert one of my own DVDs to DivX and store it on the computer. I will use DVDFab Decrypter and Intervideo DVDCopy 5. But DVDCopy stops at 99% of "preprocession" when I have chosen "DivX" to convert to. And as if that wasn't enought, when choosing whats called "DivX (Avi)" it says "Cannot Start Disc Copy". Does anyone have any suggestions why theese error messeges come?
InterVideo supports lots of formats incl subtitles (buttom at screenshot), so it could be very nice if this program could work smoothly. It seems that there's no problem when converting to the other formats. I should mention that I also have DivX Pro 6.2.5 + mpeg plugin registered on computer.
Regards
tuxi
I'm not familar with Intervideo DVD Copy, so I can't tell you whether or not it works with copyrighted discs.
You would most likely get better results and better support using different software, such as AutoGK.Google is your Friend -
The disc is not copyrighted, and "DVDFab" / "dvd decrypter" removes all protection (I have tried both). And I have no problem when just backing up the disc with dvd-shrink.
Then I expect the software is just have issues performing Divx conversion and my first post still applies.
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 12:52 -
Problem with Vob to DivX Coversion Image Size
By Baggins in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2008, 14:50 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 21:12 -
Vob to Xvid in autoGK or Divx Converter problem
By arcangel14563 in forum DVD RippingReplies: 1Last Post: 19th Nov 2007, 18:11 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 22:44
