hello
how can I see if a VIDEO_TS is PAL or NTSC?
thanks
Load one of the VOBs into an editing (MPEG VCR) or authoring software (TMPGENC DVD AUTHOR).
Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
TMPGENC DVD AUTHOR ask first to choose if its PAL or NTSC, I dont know atm
I opened a VOB with MPEG VCR, where do I see its info? -
In Tmpgenc choose PAL, then try to load the VOB.
If it allows you to load the VOB then it's a PAL VOB.
If it gives an error message then it's NTSC.
MoonstompJust because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
Originally Posted by ecos
You're welcome !Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
G-spot will tell you if a VOB is PAL or NTSC. Use the latest version - 2.52beta. Or play it back with VLC or Media Player Classic and look at the properties. Again, resolution is a good indicator. Or load the main IFO into IFOEdit.
Many options, all simple.Read my blog here.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Convert a CSS Encrypted PAL VIDEO_TS folder to NTSC DVD with subtitles
By Lord Stinkfoot in forum MacReplies: 6Last Post: 25th Oct 2007, 18:35
