INFO: [???] AC3 AUDIO STREAM:
INFO: [???] Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 9386344
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
++ WARN: [???] Stream e0: data will arrive too late sent(SCR)=350246912 required(DTS)=0
++ WARN: [???] Video e0: buf= 160628 frame=116629 sector=01025869
++ WARN: [???] Audio bd: buf= 6019 frame=121621 sector=00046332
INFO: [???] STREAM bd completed @ frame 124099.
INFO: [???] Scanned to end AU 119028
INFO: [???] STREAM e0 completed @ frame 119028.
INFO: [???] Multiplex completion at SCR=357410523.
INFO: [???] Video e0: buf= 94638 frame=119028 sector=01062691
INFO: [???] Audio bd: buf= 13312 frame=124099 sector=00047277
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 2143522888 bytes
INFO: [???] Sequence headers: 8278
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 119028
INFO: [???] No. Groups : 8278
INFO: [???] No. I Frames : 8278 avg. size 66508 bytes
INFO: [???] No. P Frames : 32772 avg. size 26021 bytes
INFO: [???] No. B Frames : 77979 avg. size 9492 bytes
INFO: [???] Average bit-rate : 4317600 bits/sec
INFO: [???] Peak bit-rate : 8986000 bits/sec
INFO: [???] BUFFERING min 15 Buf max 234468
INFO: [???] AUDIO_STATISTICS: bd
INFO: [???] Audio stream length 95308800 bytes.
INFO: [???] Frames : 3093495121
INFO: [???] BUFFERING min 67 Buf max 11683
**ERROR: [???] MUX STATUS: Frame data under-runs detected!
Process aborted due to above error
Please help. Thanks in advance
Results 1 to 11 of 11
Mplex has sometimes difficulties with ac3 streams. You can try another multiplexer (imago) and use the resulting muxed mpg (vob) file as input stream.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I am fairly new at timeI have done this previously many times had no problem. what I did
I have use ffmpugei to convert avi to ac3 format. I separately use HC encoder to convert to dvd compliant video. Finally I use DVDAuthorGui to put video, audio plus subtitle together before burning.
If I use another mutiplexer could you explain how I can put the subtitle together in the DVDauthorGUI.
Could you explain to me how to see what the ac3 f problem is with the actual avi file. Also maybe how to fix the ac3 format?
Thanks -
I can't see the whole log, but I am going to take a stab in the dark and say that your bitrate is too high in the m2v. If you post the whole mplex log, we may be able to give you a better answer.
Here is the log. I calculated the bitrate on the videocal so I dont think it should be a problem. It was set on 4323 on a 2:13:54hour.
For the life of me I did not recall how to save a word document to a png or jpg or gif. could someone remind . Here is the file in wps. Sorry. I did a search but did not find anything there was a link but it did not seem to work.
error%20log.wps -
OpenOffice won't read a .wps file. A simple txt file would be acceptable, if you don't mind.
Ok, I was able to open it on my work pc. After looking over the log, my guess is that the bitrate is spiking. You may be safe to select 'ignore errors' under file, and then author. You might also try selecting the alternate muxing engine, under tools. Borax's suggestion would also work, and then add the subtitles with DVDAuthorGUI.
Under tool, I selected alternate muxing engine:Originally Posted by liquid217
Error Message:
Unexpected error 380 in the update code. Invalide property value
DVDAuthorGUI 1.008b - 1/14/2006
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
tcmplex-panteltje-0.4.7 (c) 2001 Thomas Östreich and Jan Panteltje
INFO: using reference profile (DVD)
INFO: profile type is (PAL)
INFO:
INFO: Scanning video stream for a sequence header and pulldown type ...
INFO: no pulldown detected ...
INFO:
INFO: Scanning video stream for pictures ...
Scanning video stream: byte offset 12 of -2099881193. 0%
Tried multiplexer ac3 audio with new multiplexer imago so it was converted to vos. But dont understand how to uses DVDAuthorGUI with the vos file as my audio, add subtitle. Under add title I add the video file with m2v with no problem but when I add audio I cannot add the vos new file they ask for audio stream in ac3, mp2 and mpa. I am lost as to what to do with Borax suggestion. Could you please explain. ThanksOriginally Posted by liquid217 -
I don't know the exact procedure for liquid's DVDAuthorGUI...
AFAIK you need to select the second output format option in imago: 'VOB (DVD Video Object)'
This will give you 1 (big) vob file. Use this as video input (change the file type to vob, no m2v/ac3 specification needed, as it is already muxed!). Then select the subtitle(s), design the menu and go.GUI for dvdauthor:
Still would like to know how to do this in DVDauthorGuiOriginally Posted by trash
Just as borax said, use imago to create one large vob. Import that vob in the GUI by clicking 'add title' and under 'files of type' select mpeg/vob. Once the vob is imported, add your subtitles accordingly.
The alternate muxer is a bit buggy, and so is the interface to it via the gui, so just continue to use mplex as you can. Of course, in this case, try using the imago mpeg muxer
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 15:37 -
DVDAuthorGUI Unknown error - log included *SOLVED*
By ChibiTomo in forum Authoring (DVD)Replies: 2Last Post: 9th Oct 2007, 14:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
