Hi,
I have written my xml vcd descriptor file and have all the mpeg files encoded and ready to be burnt...
All i need to know is how to use vcdxbuild to create the bin/cue files!
This may be a rediculous sounding question and i apoligise if it is stupid! This is my first 'real' attempt at creating a vcd!
Try: http://www.geocities.com/medinotes/vcd
Assuming VCDXBUILD and the XML file are in the same directory, then open up the command console and navigate to your directory then type:
vcdxbuild myvcdscript.xml
Regards.
Michael Tam
w: Morsels of Evidence
dv cables help required
By rizvi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 18th Mar 2009, 03:05 -
Codec Required
By booyaka in forum DVD RippingReplies: 4Last Post: 15th Dec 2007, 02:58 -
Help Required. Capturing DV to PC
By jeffbhoy in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2007, 18:37 -
Software Required
By dbanga in forum ProgrammingReplies: 2Last Post: 15th Jun 2007, 06:47 -
Advise Required
By dbanga in forum EditingReplies: 6Last Post: 4th Jun 2007, 16:57
