I want to re-author a compilation of karaoke songs recorded in a DVD+RW. It already has its own menu to select what I want to play. Problem is there are some songs that I want to delete and/or trim. I also want to re-arrange the sequence. I want a similar menu for the new compilation.
Do I have to create a separate track for each song and title so that when I go to Menu creation, the songs' thumbnails/icons will automatically show in the Menu. I also want the beginning of each song to be the chapter points. Sorry, I might be misreading the guides because I could not find anything that addresses this Menu creation in detail.
Thanks.
Yes.Originally Posted by edong
It sounds like you may have VOB files on your disc - in which case you'll need to "Add DVD Video" instead of "Add File". Once added, you can then set the start and end points allowing you to trim the footage. Access this by selecting the added footage and click "Edit".
I'm basing this on version 1.5 - other versions may be different.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
TDA 1.6 menu help
By colt4523 in forum Authoring (DVD)Replies: 0Last Post: 3rd Nov 2007, 19:46 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 20:42 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 02:23
