Is AVI better quality than MPEG2 or is this a meaningless question?
Results 1 to 9 of 9
Originally Posted by jmsrickland
It's actually a good question, it's just a little hard to answer. I suppose a simple answer would be that AVI is neither better nor worse than MPEG2, but depending on the codec used for the AVI and the bitrate and resolution, one might give better results than another. For example, I would expect an AVI using Xvid/Divx to look better at a bit rate of 2000 than MPEG-2 for the same resolution. MPEG2 generally will require higher bit rates to get the same quality as certain codecs that can be used with AVI.
It's kind of like comparing apples and oranges though as MPEG2 is a codec and AVI is not. AVI is a container. -
AVI is a container, not a codec, where MPEG2 is a codec (and a container). So comparing the two is not valid.
So by the definition of "container" can I conclude that it is raw audio/video data inside an AVI file?
Are these "codec" like little code files, maybe similar to a DLL that does the actual encoding and/or compression/decompression stuff? How do authoring software know which codec to us, do thy scan your system and find the correct one? -
In case of duplicate codecs, or multiple decoders for same stream type, Windows use "merit system" to determine who gets dibs on encoding/decoding the file. You can adjust this with something like DXMAN or DSFM
The container would have a 4cc code (4 letter code usually) that will tell the file reader what sort of codec the chunks following would be using. -
you can adjust this with something like DXMAN or DSFM
mpeg2 (4:3) to avi (16:9)
By kouras in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 09:53 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 08:44 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42 -
avi to mpeg2
By n2lakers in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 14:56
