hi i've created my first SVCD and i pld it on my Sony DVP-NS700V but the playback isn't smooth and i was wondering wat setting i need to adjust in TMPGEnc-2.50 to make it run smoother
thnks
mpeg-2 video
480x480
aspect ratio: 4:3 display
frame rate 23.976
CBR 2259 bitrate
buffer size 112
video format: NTSC
non-interlace
DC: 10bits
Motion search: high quality
Source aspect ratio: 16:9 525 line (ntsc)
Full Screen (keep aspect ratio)
i'm trying to convert divx film to svcd
what i need to change for smoother playback?
thnks -
What's the audio playback like - does it drop in and out but still remain in sync witht the video?
If so, I'd suggest lowering your encode CBR to something around 2000 (or even lower).
Your player may not be up to the task of such a high CBR.
Hope this helps.
Sue xxx. -
the audio seems to be alright, tis a NTSC film does that mean i ave to set the frame rate to 29.97?
even tho the film runs @ 23.976 when i ply it on my pc -
Yes 29.97 is a must in SVCD playback. You will can either encode in 23.96 fps with "2:3 pulldown when playback" option set or encode in 29.97 fps.
Any way to keep smooth mpeg2 playback with Handbrake?
By Forty0zFreedom in forum Newbie / General discussionsReplies: 11Last Post: 26th Apr 2012, 16:58 -
filter to smooth playback?
By kinglerch in forum EditingReplies: 14Last Post: 21st Oct 2011, 14:17 -
DVD to MP4 conversion playback not quite smooth.
By scottb721 in forum Video ConversionReplies: 1Last Post: 21st Jun 2010, 10:45 -
How to test smooth x264 1080p playback?
By tsoukkis in forum Software PlayingReplies: 1Last Post: 26th Oct 2009, 07:43 -
WMV settings for smooth playback
By sumario in forum EditingReplies: 0Last Post: 3rd Jul 2008, 21:31
