Is there other software that I can use to capture TV input other than the application that came with my TV Tuner card or is it pretty much propriatary stuff?
I have an AVerTV GO 007 FM Plus TV Tuner card adapter. The adapter is fine. The software that came with it sucks.
Results 1 to 11 of 11
Try VirtualVCR. It's free and it's good. At least worked well for me when I had a software encoder card.
Well that is one lttle wierd program. I went into the settings menu option and set the Channel to 3, Country to 1, Tuning Space to 0, Tuning Mode to TV, Video Standard to NTSC_M, Input to 1 and Antenna and clicked on Apply. The Apply button never came back from it's disabled state until I pushed the OK button then it became enabled again. Not sure if I really applied the settings. Appearently not because everytime I went back to the main screen I always got black, nothing else. While I was in the settings menu I could see video from the TV set as well as video from a VHS tape. Then I clicked on the Save settings menu option and it came back and said that my settings were saved as the default. Not true. Every time I launched the program I got a black screen. I had to go back to settings and the settings were set to what they were before I made the changes. So I had to make to changes again and save them again. But again the program does not save the settings.
OK, so I went into the folder where the program was installed and edited the .INI file manually by changing the Channel to 3 and all the other settings that I had already done in the setting option panel. OK, I finally got video now from both TV and VCR but there is no sound. I have no idea what to do to get sound. -
Check this link out:
https://www.videohelp.com/tools?s=5#5
There are plenty of other free capture programs you can try. Its in the TOOLS section
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Holy Bunch Batman! That's alot of stuff there. I'll just begin at the begining and try each one.
Good luck
If that is a semi standard Conexant chip based card, there are many.
If you are looking for a shortcut, a few bucks (amout depending on shopping skills) gets you ULead Video Studio. It is a good starting point with minimal negatives other than too many features.
http://www.ulead.com/vs/ -
I have Video Studio, I just didn't know it could do that.
Ok, I used VS to capture from the TV-Tuner adapter but still no sound.
If I use the software that came with the capture card I get sound. -
These cards use the sound card for audio. Some use a cable to connect tuner audio out to line in on the sound card, others exchange audio through the PCI bus. Consult your documentation or call AverMedia support.Originally Posted by jmsrickland
OK, thanks, but before you posted above I got it to work. I just went in and started to play with some options on VS.
I think VS is alot better than that other application besides VS gives me more output formats to choose from while that other only gave AVI as output.
Anyway, thanks for the info about VS; I never knew it could capture through a capture adapter.
Recommended TV viewing software for ATI Theater HD 750 tuner card
By MJPollard in forum Newbie / General discussionsReplies: 7Last Post: 30th Nov 2010, 19:22 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
tv tuner card help!
By johanc in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2008, 07:02 -
Need Software For TV Tuner card.
By arshadmahmood in forum Capturing and VCRReplies: 1Last Post: 8th Oct 2008, 14:30 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
