Hi,
I have some episodes of a manga that is in IFO, VOB and BUP files. The subtitle is in english and japanese, and I want to edit the english subtitle because it is often spelled wrong here and there.
Is there any easy way to do this? Im a totally newbie so please explain this so that even a baby could understand. Thanks alot!
Results 1 to 14 of 14
no, no easy way to edit the text. you need to demux to text subtitles, subrip, and then edit them, subtitle workshop, and then reauthor , muxman.
Thanks. Is there any guides for those programs? I very green when it comes to DVD-editing.Originally Posted by Baldrick
I personally use a DVD ripper to take all the video with the subtitles, then use Subrip to turn it into text form (usually SRT, i.e. subrip format). THEN edit with Subtitle Workshop, then reauthor, but one at a time.
Try Subrip on your existing movie first, see what it pulls out. Try a few. Once you get it, then play with Subtitle Workshop a bit. Once your'e happy, THEN play with reauthoring with Muxman. -
Thanks, this is quite funOriginally Posted by kschang
I have used SubRip to get the subtitle to an SRT-file, and then I saved that file and opened it in Subtitle Workshop. Now I have done all the changes that I wanted, and my next step is to try this Muxman. Only thing is that I don’t know the program or what it is used for, what do you guys mean by reauthoring? -
You have to put the pieces back together again, the video, audio, chapters, and subtitles. If your movie isn't in elementary streams already (separate audio, video, chapters, subs), then demux using PGCDemux first before reauthoring using Muxman. You'll need the subtitles in SUP format (or SST) if you're going to use Muxman. If you want to use the subs in SRT format then DVDAuthorGUI, among other programs, can reauthor it. It has its own requirement for chapters format, though.
You can also use VOBEdit to demux.
Here's a guide: https://forum.videohelp.com/viewtopic.php?t=245188 -
The files are in VOB, BUP and IFo, do I still need to use PGCDemux to do this elemtary streams thing? I have tryed PGCDemux but it cant open the original files...
If you're going to author using Muxman, as kschang (and I) recommends, then it accepts only elementary streams. If you try and open the IFO in PGCDemux, and it can't open it, then there's something wrong with the DVD, I'd say. So, maybe take MOVIEGEEK's suggestion. -
What do you mean?
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Can the subtitles that are changed be saved on the dvd that they were ripped from? Or can they only be saved on a blank one? If so...I'm totally lost. Please help...
You'll have to reauthor the DVD, or, in your words, saved on a blank one. The instruction for doing that were given earlier in the thread.
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 21:15 -
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 03:06 -
Burn VOB without BUP IFO [Special]
By ron007 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2009, 21:01 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 17:26 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 13:10
