Does anybody know a few details on how the Commercial pressing of CDs and DVDs is achieved?
I mean, how is the foil duplicated in so many copies and how are they attached to the plastic.
Not sure which element you're referring to when you say "FOIL".
In a nutshell,
Most factories stamp the pits into plastic, apply a reflective (maybe "foil" here) layer by "sputtering" (like machinegun spraying w/ spinning), then do the same for additional layers, all the while sputtering some "glue" layers in between.
They fill out the remainder of the substrate with polycarbonate filler so it's a smooth full disc.
Then, they silkscreen the artwork.
wanted DVD to MKV that works
By jack616 in forum DVD RippingReplies: 2Last Post: 29th Nov 2011, 08:42 -
Wanted to put 4 CD's on one DVD
By happydog500 in forum AudioReplies: 2Last Post: 16th Sep 2011, 19:15 -
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 08:21 -
Windows Movie Maker Will Not Start Timeline When Pressing Play
By kerrex_2006 in forum Software PlayingReplies: 0Last Post: 8th Apr 2010, 11:10 -
Pressing Capture Button Freezes Program
By Mengsk in forum Capturing and VCRReplies: 13Last Post: 5th Jun 2008, 16:45
