Hello, I've been using the Alparysoft Denoise Filter with Vdub. In my opinion, it's one of the better denoise filters out there.
The problem is, when I playback the output file, there is an "Aplarysoft" logo in the bottom right hand corner of the screen.
Does anyone know if this is permanent? If it will be part of the file once it's put on DVD?
Or is there a way to remove it?
Thanks!!
Chris
Results 1 to 1 of 1
avisynth denoise filter applied only from frame x to frame y
By codemaster in forum Video ConversionReplies: 1Last Post: 26th Apr 2012, 13:22 -
Denoise filter ? which one is the best ?
By cd090580 in forum Newbie / General discussionsReplies: 35Last Post: 19th May 2011, 10:34 -
Help with Denoise Filter
By skorpinok in forum Video ConversionReplies: 0Last Post: 1st Jan 2011, 03:59 -
Camcorder Color Denoise Filter for VirtualDub
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 17th Mar 2008, 14:30 -
Alparysoft Deinterlace for AVISynth problem
By _migz_ in forum Video ConversionReplies: 5Last Post: 3rd Aug 2007, 08:54
