Hi,
Ccn somebody to advice me how to make a Portable dvd player to "gain" the capability to read PAL DVDs? My model is Philips PET724
Thank you for your help
alx
Hi,
A review of this player (on this site) says it is switchable from NTSC to PAL.
To make it "Region Free" - there is a hack (on this site). Here are the instructions given:
Region code hack posted by Jose, April 20 2006:
Multi-Region:
Switch player On and Open tray door
Press Setup on the remote control
Move menu selector down to Preferences and press Right arrow
Press 2, 1, 2, 2, 2 and 5
Press Left Arrow
Press Down Arrow
Press 0 when the screen displays region code
Press Setup to exit
Good luck !
MoonstompJust because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
