Hi,
I gave up on archiving my copy of Fargo. I ripped the widescreen side using Smartripper, ran it through dvd2avi and encoded with TMPGEncoder. I tried all different settings but the VCD is still full screen and everything is squished. It is watchable but since Fargo is one of my favorite movies I wanted a GOOD vdc backup.
If anyone can make any suggestions it would be greatly appreciated.
Thanks,
~dev
two things to change in TMPGEnc - Settings / Advanced:
Aspect ratio: 16:9 Display
Video arrange: Full Screen (aspect ratio 2)
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Use FitCD (you find under tools) Load up your movie under mpeg resizing. select your setttings (read the help file). In tmpgenc under advanced settings choose 1:1 vga and under video arrange method choose center (custom size) and enter the resizing FitCd calculated for you.
Good luck
frotsen -
Sefy's suggestion worked great. I never used Aspect ratio: 16:9 Display, before.
Thanks,
~dev -
Glad to be of help
Let us know if you have any further questions!
Best Regards,
Sefy Levy,
Good luck
frotsen
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
i find myself using "center (custom size)" more and more, since there are times, many times, where the aspect ratio on the final MPEG's playback is "off" when using video arrange method "full screen (*)", no matter what aspect ratio i use for the source (always 4:3 on output aspect ratio). using the video arrange method of "center (custom...)" allows me full control of the final mpeg's output/playback, even with 352x480 XVCDs. i've even redone some older XVCDs to correct aspect ratio's which were slightly off.
p.s. redoing XVCDS?! i've gotta find another hobby!!
<font size=-1>[ This Message was edited by: hitechjunkie on 2002-01-09 13:01:35 ]</font>
uploading multpile files in one sitting ? ... [gave up on]
By vhelp in forum FeedbackReplies: 0Last Post: 18th Jan 2010, 17:37 -
How to rotate a MOV file? I just gave up.
By Pixelrage in forum EditingReplies: 10Last Post: 28th Oct 2009, 22:30 -
Why is an 1100 bitrate giving me a 6.5gb file when before it gave me 1.1gb?
By happyprozak in forum Blu-ray RippingReplies: 1Last Post: 27th Nov 2008, 13:10
