    Jul 2006
    hi, i put the video clips i captured with my digital camera (casio exilim 850) and i tried editing it with sony vegas but for some reason there is no video showing. i am able to import it into the software but there is no video. how could i check compatible formats? do i need to convert? any help please.
    Apr 2004
    Miskatonic U
    it is probably mjpeg. Try using SUPER to convert it to DV or losslessly compressed avi and loading that. Avicodec will be able to confirm the codecs used to create it.
    Read my blog here.
    USA
    Looks like it uses: Movies: AVI (MPEG-4) Audio: WAV
    I would try SUPER also to convert it to another format.
    Jul 2006
    thanks guys, i'll let u kno if it works.
    *UPDATE alright i got it working by converting it to wmv...one last question, where is the option of converting it to DV?
  5. Mod Neophyte redwudz's Avatar
    USA
    What program are you using to convert it? If it's SUPER, select AVI for the container and try HuffyUV for the codec and see if Vegas accepts that and skip WMV entirely. At least in my version of SUPER, DV is not a option for encoding to.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you can load it into WMM then you can output DV
    Read my blog here.
