Hi all
I am a newbie in dvd authoring techniques
I am having a problem with a dvd that I have downloaded from the web , it was working fine so I have burned it to a dvd and deleted th original files
but on displaying I found that it hangs seconds before the end of chapter2
in my case I checked the vob file and I have found that VTS_04_1.VOB is the one having the problem
is there anyway it can be fixed or reauthored by extracting the vob element and re encoding it again
If you corrupted it with a bad burn then chances are you won't be able to fix it completely because the data is gone. Lesson one for the day - always test before deleting the originals.
Extracting a single title from an authored DVD, then putting it back, is fraight with danger. You are better off etracting all titles, trying to repair or salvage, then re-authoring with what you have left. There are plenty of tools to do this - rejig is one.Read my blog here.
mp4 file corrupted. Very important file. Need some help!
By seanloughry in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2011, 18:54 -
Mp4 file corrupted
By petter in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2010, 00:02 -
corrupted dv file
By marshs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Aug 2008, 18:40 -
Corrupted vob file(s)
By Mållgan in forum Authoring (DVD)Replies: 6Last Post: 9th Aug 2007, 09:25 -
Corrupted VOB file
By peterson1975 in forum Video ConversionReplies: 3Last Post: 20th May 2007, 19:10
