Hello all I have tried numerous time to burn home HI8 movies using a dazzle dvc80 and the MM2 or Studio8 software. I have tried to close all open programs, buy better discs, buy an adapter that plugs the 2 audio jacks into a mic piece that bypasses the dazzle and goes directly into the computer. The preveiws all look fine with both video and audio but when I burn the disc the audio is distorted. Somewhere in the burning process I'm losing the audio. I need help as I been trying to fix this for 4 days and alot of coasters. Thanks John
Have you tried lowering the volume on the input slider on your sound card? Maybe the gain is too high.
Also try running it through an external stereo and then to your soundcard. Maybe it needs signal boosting before it hits your pc.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Capturing Hi8 video using Sony TRV320E D8 (PAL) camcorder distorted audio
By lchiu7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Sep 2011, 17:39 -
Audio Sound Distorted
By Teac23 in forum Software PlayingReplies: 0Last Post: 1st Aug 2010, 08:40 -
Audio distorted when converting MKV to DVD
By excite in forum Video ConversionReplies: 38Last Post: 21st Jun 2008, 12:56 -
distorted audio
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 20th Mar 2008, 15:11 -
Staticy/distorted audio exp'd when copyin some home-rec'd VHS movies to dvd
By corneileous in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2008, 18:33
