i have been trying to convert a film to vcd using winavi but everytime i try it copies it upside down can anyone help me or can anyone suggest a different coverter to try i have never had this problem before
Try WinAVI support. They are forever spamming here to tell us how good they are.
Otherwise, ditch the piece of crap and get a better encoder. If you are only doing VCD, then the free version of tmepgenc encoder will do a great job. You get mepg2 encoding for two weeks, and after than, mpeg1 only, which is all you need for VCD. And it is a much higher quality encoder than WinAVIRead my blog here.
In the advanced seting,there is an option you can flip picture upside down.
Winavi problem
By Qvezzy in forum Video ConversionReplies: 2Last Post: 3rd Mar 2010, 15:21 -
I can't use WinAvi 9.0.
By dualinline in forum Video ConversionReplies: 2Last Post: 19th May 2009, 07:47 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Winavi 8.0 Help
By agkoichi in forum Video ConversionReplies: 1Last Post: 26th Jul 2007, 03:17
