Hi,
I'm having this problem since I'm using winxp. Every time I convert a divx movie into vcd (pal) tmpgenc makes the movie twice as long or even more. The previes frame freezes after about 50% in tmpgenc. When I play the mpg file using windows mediaplayer it works fine except mediaplayer sees the file as a 3 hour movie (it was 1,5 hour) and when the movie is over I get a freezing image of the last frame of the movie for 1,5 hour. The file size is twice as big as it should be 2. What can I do? I used version 2.02 and 2.50 but there is no difference. A friend of mine uses xp 2 and has no problems (I used ME before and had no problems)
tanx for the help...
greetz kelu
(os pentium III using xp-pro)
<font size=-1>[ This Message was edited by: Kelumenati on 2002-01-08 07:17:01 ]</font>
