i thought that cd are in mpeg-1 format but it was in .DAT format
also DVD not in MPEG-2 format but in .VOB format
i mean how can i burn .XviD and WMV AND RM files on vcd or dvd
thx in advance
AND
in what quality my file should be that after change to mpeg-1 1.1 mbps
i can get good quality
is 15000 mbps enough for this
AND
is there a quality or size different between two .mpeg-2 and .vob file(bothe in 9.5 mbps and 720*572
please answer to my three questions
isobuster can get the mpg from a dat file.
dat is a storage container file type as is vob. MPEG 1 is the video format for vcd and mpeg 2 is the video format for dvd.
15000 mbp is above the dvd standard.
This will give you the basic specs:
https://www.videohelp.com/dvd
Again vob is the container for mpeg2 files to make a dvd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thx but i mean when i buy a vcd from outside the quality is really good but when i try to capture mpeg-1 the quality becomes bad.why?
and can i burn XVID on dvd or vcd like mpeg? -
Professional dvds would use a higher quality source.
You can burn a xvid as a plain data file but you will need a divx compatible dvd player to read it. Otherwise you will have to convert the xvid to mpeg2 and author a dvd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
VCD's are generally down-converted from DVD's thus they have good quality visually, at least on regular TV.
See the tools section for AVI -> VCD/DVD converters (it's skipping a few steps, but there are tools that do that)
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 06:21 -
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
Need something that will multiplex .m2v, .ac3 AND .dat into one .vob?
By Information in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 01:06 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10
