I've been using Ulead DVD Workshop 2 to do authoring because it's easy and fast and I can create a menu from start to finish all within that one program.. Just wondering if any other programs have been released lately that allow me to accomplish the same task? DVDWS2's text editing capabilities could be better in my opinion.. Someone told me to check out TMPGEnc DVD Author 2.0 but I'm not sure if it has the capability? Anything else out there? Don't say DVD lab, that program is just plain cryptic to me =)
For your requirements, you are probably using the best program already. TDA is probably easier, but not as powerful. Encore is more complex, and doesn't allow for all DVD compliant resolutions to be used. I use DVD Lab Pro, but I understand that it isn't for everyone. I use very few of it's built-in effects and menu features, and do most of my work in photoshop first.
What specifically is wrong/missing/lacking in DVDWS2 that has you looking elsewhere ?Read my blog here.
Better text editing capability.. I'd also perhaps try to use photoshop to create the menus but I'm not sure how to make DVDWS2 import those files.. There's another program by the same people that make DVD Lab called Menu Studio specifically designed for creating DVD menus but I can't figure out how to make it work with DVDWS2 either.
Does arcsoft total extreme have a 3 hr maximum limit for authoring?solved??
By yoda313 in forum Authoring (Blu-ray)Replies: 0Last Post: 11th Mar 2011, 13:41 -
DVD authoring/editing questions from a total n00b
By DesertAvenger in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2009, 13:39 -
iPod last.fm-type statistics program (total songs played in last week, etc)
By Salva Veritate in forum Portable VideoReplies: 0Last Post: 22nd Jan 2009, 16:54 -
Best Authoring Program to create full custom menu
By quik_123 in forum Authoring (DVD)Replies: 12Last Post: 11th Oct 2008, 01:46 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 19:27
