I have several avi videos that I would like to burn to a DVD. Is there a way I can get SVCD 2 DVD to pad the output so that my 320x740 video is not stretched. It is fine with me if its a small square on the screen. It just looks bad if the video is stretched...
While it's in AVI format you could use VirtualDub and the resize filter. Just leave your video the same size and add black frames around it till you get to the size you want. You will probably have to re-encode it, though.
need free program to quickly losless crop an mpeg2 740x480 to 720x480
By wolfdogg in forum Newbie / General discussionsReplies: 5Last Post: 13th May 2011, 17:49 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 10:13 -
best lossy codec for 320x240 video
By videoasker in forum Video ConversionReplies: 12Last Post: 30th Jan 2010, 12:56 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 09:17 -
320x240 res video onto dvd
By scarypoultry in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 16:30
