I am not sure this is the right place. I am interested in writing software to create video email. I want to capture the images using a webcam connected through my usb port and save the files in mpeg or jpeg format, to be viewed on other systems. Is this the correct website to find help on how to do this?![]()
The "Peter Principle" states an individual will rise to his or her level of incompetence.
You are probably in the right place.
If the images you are capturing are from the computer screen, there are better ways to do that: https://www.videohelp.com/tools?s=110#110
But if you just need to capture webcam video, then it depends on your webcam. They usually come with some sort of software to save the video. Then you could convert it to what format you want.
BTW, Your signature is violation of our rules. We don't allow political comments here. Please remove it and read our rules before posting.
Moderator redwudz
And welcome to our forums.
Sorry about the signature. The webcam software did come with a capture routine, I just need the challenge. Thanks for the reply.
The "Peter Principle" states an individual will rise to his or her level of incompetence. -
If you plan on writing the capture program yourself, you should start with researching either WDM or DirectShow. Since WDM is public source, it might be a good place to start.
General Cable question
By acrumbacker in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2011, 22:00 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 11:58 -
General question about blu ray files and HD
By True Colors in forum Newbie / General discussionsReplies: 8Last Post: 22nd Dec 2009, 18:23 -
General Bluray \ HD question
By Shayetet13 in forum Newbie / General discussionsReplies: 6Last Post: 7th Oct 2008, 03:08 -
videohelp bitrate calculator question
By mrgain in forum EditingReplies: 5Last Post: 24th Oct 2007, 16:56
