Chrissyboy,
My copy of SVCD2DVD seems to have changed the fit to DVD size from 4.36 to 4.37GB. I don't know if I did it or even if that is supposed to be changeable. Anyway, when it comes time to burn, DVDDecryptor stops because the iso files are now too big to burn. Any way to change this back to 4.36?
Thanks,
Mark
A search turns up this thread:
https://forum.videohelp.com/viewtopic.php?t=285423Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Have a look at:
https://forum.videohelp.com/viewtopic.php?p=1413094#1413094SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for the link to the thread that relates. So I would add the value to the registry and subtract 1MB from 4370 to get back to 4.36GB? If so, that is great, I will give it a try. That doesn't explain why this value has changed to 4.37 though. I didn't add anything to get to 4.37. I have a copy running on a 2nd computer, same version of windows and it's fit to DVD value is 4.36. Why the difference? Why should I have to go into my registry and edit a value to get back to the value it is supposed to be in the first place?
Thanks,
Mark -
No - you need to add around 10MB. the 4.36/4.37 issue will be down to rounding... by adding another 10MB to the value in the registry you are adding another 10MB as a safety margin (incase the calculated size over shoots.)
Chrissboy,
I must be really dense because after your help here and reading the attached link, I still do not get it.
I have added the the string value DVDSIZESAFTYMARGIN to the proper place in the registry. I have entered a value of 10 in the value box because you said to add about 10. Yet I open SVCD2DVD and it still says 4.37GB when "Fit To DVD" is selected. I know I must be doing something wrong. Please tell me, what value do I put into the registry value box to get a 4.36GB DVD as the final output?
Thanks,
Mark -
well the default is 50MB so a value of "60" would be 10 more... If that is not the case just increase the value till you get the correct result.
DVD player "STOP" function question
By efiste2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2012, 16:27 -
Help. Avisynth Error Message "no function named limitedsharpen"
By Pitorasilo in forum Video ConversionReplies: 7Last Post: 27th Dec 2010, 06:13 -
Problem with meGUI's "Analyse"-function
By FallenAngelII in forum Video ConversionReplies: 2Last Post: 4th Dec 2008, 19:34 -
Help. Avisynth Error Message "no function named deblock"
By hypnoticpimp in forum Video ConversionReplies: 13Last Post: 27th Sep 2008, 23:45 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 20:52
