hello
I have found many subs for a specific movie, but I load them and none works
is there any procedure to identify if the subtitle is the most compatible one?
eg, what player to use, how to load, etc etc
thanks
Subtitle Workshop also allows to load video and subs separately and immedeately adjust them!
Cann't tell it's possible don't tell anything.
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 03:17 -
De-muxing and finding an extra subtitle with Tsmuxer
By cal_tony in forum SubtitleReplies: 2Last Post: 23rd Aug 2011, 10:56 -
problem with DVDShrink finding files
By chaskar in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2010, 16:48 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59
