Is there a way around this? I am trying to combine my kids dvd from 4 to 1 cause I am tire of switching it every 30 mins. I copied the ts_video folder but when I try to select it from.. I get "cannot import the contents of copyrighted dvd" message. Is there an easy way to combine the dvd? Thanks.
Try copying the VOB files to your computer using DVD Shrink or DVD Decrypter or any of the ripping tools here ... you have to remove the encryption... there are tons of guides available here too, on how to do it...
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
How do I copy VOB files using DVD Decrypter? I can only see the option of read it as iso.
Never mind, I found the guide for dvd decrypter. Thanks.
http://www.dvd-guides.com/content/view/23/59/ -
or dvdfab decrypter, no guide required...just click start...
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 10:45 -
DVD Recorders and copyrighted TV
By InXess in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2010, 13:26 -
TMPGEnc DVD Author 3 can't import AVI video, only audio?
By XyBeRz in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 09:54 -
How do I convert my copyrighted DVD's into 3gp? How do I do part of a DVD?
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 8Last Post: 8th Jul 2008, 22:31 -
DVD RIPS (non copyrighted) for educational use...
By Spooky_uk in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2007, 18:33
