hi
is there any way to tell what the max speed of your cpu fan is while its installed?
thanks![]()
You can try and use Speedfan.... It shows alot of info on the Temp and Fan speeds...
http://www.almico.com/speedfan.php -
i already have software thet monitor temps for my mobo , cpu. i'm looking for something that can tell me what my max cpu fan speed is , not what its currently at.
thanks anyway tho
If it's a aftermarket fan/cooler, go to their website.
Generally, they don't have extreme ranges. If it's running at 2KRPM, then it probably maxes out at 3K. If it's running at 4KRPM, then maybe 5KRPM. You can also look at the label on the fan, it may tell you the speed range. Or if there is a part number and manufacturers name, check the fan manufacturers site.
If it's controlled by the motherboard, you can disable the software control and it should run at max. If it's internally controlled, do some heavy encoding and see what it goes up to. Run your CPU at 100% for a half hour, that should max it out. Most encoding is at 100% CPU. (As measured by Task Manager in XP.) -
its intel fan that came with cpu. thats a great idea about encoding so thats the way i'll go as i'm getting tired of taking my pc apart all the timeOriginally Posted by redwudz
thanks
CPU Fan has failed please advise
By V Bot in forum ComputerReplies: 21Last Post: 23rd May 2010, 15:47 -
Auto shut down for CPU fan?
By HotDamn! in forum ComputerReplies: 7Last Post: 24th Apr 2010, 10:37 -
CPU Fan Died, Why No Warning?
By DarrellS in forum ComputerReplies: 14Last Post: 21st Feb 2010, 19:15 -
CPU Fan is on high all the time
By alegator in forum ComputerReplies: 16Last Post: 26th Dec 2009, 22:23 -
CPU fan spins, but no motherboard beep
By gooberguy in forum ComputerReplies: 23Last Post: 30th Jun 2009, 16:54
