I'm looking for recommendations for MPEG-2 capture software that can adjust audio lower as its being captured because I have old VHS tapes that when captured have loud noise in parts.
Thanks for any help.
Results 1 to 9 of 9
I havenīt used Nero for capturing and donīt really know if it has what you need. I have Premiere 6.5 and you adjust the audio AFTER you have captured it. I also have studio 9.4 (it came with my Studio Deluxe card, wich can capture from analog sources and also capture MPEG "on the fly"); Studio 9.xx also has video and audio settings that you can adjust when you capture from analog (like your VHS tapes), you can control input volume, image contrast, brightness and color, etc...I think it does just what you need (provided you have a capture card with analog inputs). One last thing is that I only use Studio 9 for capturing video, I donīt edit it with it (Premiere is much better ) and neither try to do any authoring with it (it īs too buggy and crash prone), just capture.
Ok thanks, I presume you mean Pinnacle Studio 9? if so, I'll try a trail run and see how it goes.
Ok, got Pinnacle 10 and it says I need 512mb minimum memory and the max I have is 512mb. So looks like I need alternatives.
You can use any software because when you capture analog(using a PCI card) you can adjust the volume by using Windows volume control->Line-In:
If you capture analog with a USB device you need a mixer between the VCR and PC,if you capture through a camcorder via firewire then between VCR and camcorder:
www.activemusician.com/item--EM.PHN-MU502/ref=fg
or
www.radioshack.com/sm-4-channel-stereo-microphone-mixer--pi-2102920.html -
It's USB and I don't see myself shelling out more money for a mixer. Thanks for your help anyway. There must be some kinda software out there.
Seeking Software to Capture DOS Screen Motion and Audio
By Frank-0-Video in forum ComputerReplies: 3Last Post: 10th Jun 2011, 23:57 -
need mkv to DVD mpg converter program that gives and adjusts output size
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 3rd Mar 2011, 02:57 -
Problem recording audio from screen capture software.
By nick101181 in forum Video Streaming DownloadingReplies: 1Last Post: 12th Sep 2010, 01:40 -
Software that adjusts color and brightness of video
By ericdunn in forum Newbie / General discussionsReplies: 5Last Post: 24th May 2010, 07:48 -
Need help with audio recording software that adjusts microphone input
By jimcornetet in forum AudioReplies: 3Last Post: 24th Apr 2010, 02:01
