i bought fast dvd copy but the program does not work i dl it then try topen it and it wount open. when i dl it.the file name is fastdvdcopy4.0.4.dmg-3.hqx but each time i dl it the 3 changes to the number of how many i dl so far. so i also look at the faqs on the site it said to rename the file so i did to fastdvdcopy4.0.4.dmg then try to open it it said "the follwing disk images failed to mount" then in the box it said image witch is fastdvdcopy4.0.4.dmg and the reson witch is "not recognized". can anybody help me get it to work because i paid lots of money for it.
The .hqx file is encoded with BinHex. I believe Safari should decode this automaticly in the background, so that you'll end up with a .dmg file. Firefox gives the user a choice to decode the .hqx file with StuffIt Expander (to .dmg) or download to file (as .hqx).
You may decode the .hqx file with StuffIt Expander manually at any later time, of course. -
I would suggest contacting the folks you bought it from, for help.
hard copy subs without changing codec fast
By Ceesar in forum SubtitleReplies: 15Last Post: 21st Oct 2010, 11:38 -
avchd copy to mac
By thomas basham in forum MacReplies: 1Last Post: 22nd Jul 2010, 13:35 -
I'm an idiot! How do I copy a DVD using Mac The Ripper and Toast 10?
By brido7760 in forum MacReplies: 2Last Post: 20th Jul 2009, 12:42 -
copy dvd for Mac
By air in forum MacReplies: 3Last Post: 7th Nov 2008, 15:25 -
Fast fix
By ingeborgdot in forum Newbie / General discussionsReplies: 9Last Post: 5th Sep 2008, 12:09
