I have a .avi file that gspot tells me is a matroska media file. I'd like to convert to divX/Xvid but can't open it in Virtualdub. I've followed the guide for converting .mkv to avi using virtualdubmod or MVKextract, but i just get error messages. Tried changing the extension from avi to mkv but that didn't help. Can anyone here help please?
Results 1 to 17 of 17
Hmm... that's odd. I didn't think GSpot had much support for Matroska files (but I'm willing to admit I'm wrong
). Which version of GSpot are you using? Also, it might be a good idea to post a screenshot of the GSpot window in question here (if you prefer, blank out the filename/path) so that we can examine it.
If cameras add ten pounds, why would people want to eat them? -
It might help if you said what error message you got when opening with VirtualDubMod.
So what happens if you rename the extension to MKV, and use MKVExtract to open it?
I got alltoavi to run, but when i pressed "execute job"it just wiped the file clean off my HD. Good job i'd copied it first. MKVextract just says "files extracted successfully" (or files demuxed successfully in gui 1.6.2), but doesn't actually do anything.
i extracted and installed MKVExtractGUI-1[1].6.2.zip, mkvextractgui.zip, Matroska_Pack_Full_v1.1.2.exe,
MKVExtractGUI requires mkvextract plus dependancies from mkvtoolnix to run.
MediaInfo would give much more usefull info than GSpot. For instance the video could already be XviD or you meant that you want to convert to an avi? -
Had more luck after i ran the avi through avimux to produce a slightly smaller file with an mkv extension. This "opened" in virtualdubmod, but immediately closed. Alltoavi opened it, processed an .avc and .mp3 file, but after the muxing into an .avi all three files just disappeared at the end. After installing the latest ac3 codec, i managed to open the original.avi in TMPEG (v12a) and produced an mpeg2 file which i'm now converting to Xvid using VirtualDub mpeg!
Here's a shot of the original avi file in mediainfo in case anyone can think of a more elegant solution that actually works
The latest ac3 filter enabled me to open the avi file in goldwave and extract the audio, and it allowed tmpegenc to convert the audio as well as the video. Didn't need besweet.
Vualdub - open MKV with Matroska plugin - MISSING CODEC
By pchan in forum EditingReplies: 5Last Post: 20th Dec 2011, 08:50 -
AVIAddXSubs matroska support?
By therock003 in forum SubtitleReplies: 9Last Post: 3rd Mar 2010, 08:21 -
Demux Matroska files
By Anicsi in forum MacReplies: 4Last Post: 16th Dec 2009, 12:41 -
Searching for matroska/MKV Codec
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2007, 09:54 -
Problem playing .mkv (matroska)
By mk2006 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2007, 04:33
