I have looked over several topics and tried several things. Could you please expain how exactly I can convert a bin/cue to another format. re: avi, mpeg, etc...
Is it possible? Please Help
Ok thank you but . I have no idea how to make this work. I am using a Mac. And that program you reccomended is in the terminal mode and I have no idea what I am doing.
I tried like the instructions said but it keeps saying bad command.
Could you please give me a little more detailed response?
Thank you.
I'd use Gumby for such extractions. Open the SVCD Jelly module, hold down the Option (Alt) key, the Process button changes into Extras, press Extras, drop the .bin file in the Source field, set the Multi-stream extraction selector, click OK, select a save location, wait for the extraction process. You'll find a Extracted Files folder in the selected location, which contains the KVCD as MPEG file.
The advantage of this app's Multi-stream extraction is
(a) it works for (X)VCD and (X)SVCD, so you don't have to choose VCD or SVCD;
(b) it will save an MPEG file for each stream it finds (where regular extraction might give weird results if the .bin file contains more than one stream, like stills or intros).
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
