I'm ripping this DVD (with DVDShrink, DVDDecrypter, Smartripper) I made which is in perfect condition and I get to a certain point and these rippers can't read it and stop. DVDShrink gets to a certain point when analyzing and just stops. I haven't had any problem ripping my DVDs (I rip several per day). Is this just bad data on the DVD?
probably bad data if the disc itself is impeccable. Then again, ripping several discs per day could be slowly damaging your drive.
We would need more information. What programs did you use to make the disc? Did you use a set-top dvd recorder? If you made this disc, why not copy it through windows explorer?
If you made this disc, there is no reason to run a decrypter, because it is not encrypted.
The disc could be bad.
A last resort could be running isobuster. It will sometimes rescue data from bad discs.Believing yourself to be secure only takes one cracker to dispel your belief. -
I used DVDLab to make the disc. I tried copying it thru windows explorer and same thing happened. I just ripped one of my discs a few minutes ago and no problem.
I looked at the sectors in Isobuster and there were all "0"s but there was a section where there were "F"s and "?"s. It couldn't read it, either.
The DVD plays fine on my standalone player. I don't get it. -
As strange as it may sound, I had the same problem yesterday. I could copy one of my self-made dvds with DVDwasher, another one with DVDFab Decrypter, and the third one with FixVTS.
Iso thing did not work, either.
I don't know why, at all...They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
That's why I keep the project files on all my home made DVDs You can never tell when your "Copy" with not "Copy" a second time.
No DVD can withstand the power of DVDShrink along with AnyDVD!
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 01:00 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 15:23 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 17:24 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 08:17
