  1. How do I find out if my input file is Progressive or Interlaced?
    I didn't capture the video (downloaded it instead).
    Thanks!
    Most downloaded video is progressive. dv-avi and some mpeg2 might be interlaced.
    but you can open the video in for example virtualdub or virtualdubmpeg2 and check...interlaced looks like
  3. Great!!! Thanks!!! The reason I ask is because CCE SP gives me an option to tick if my input video is Progressive. I know now, from your answer, that it's not Interlaced!!
    Thanks again!!!
  4. Member Cornucopia's Avatar
    Remember to check a whole range of frames. On material that has been hard telecined, you will find some frames that look OK (progressive) and some that have the mouse teeth (interlacing), actually in a fairly regular pattern. True progressive would have NO intelacing. True interlaced material, OTOH, will have many frames that LOOK progressive if nothing in the scene is moving at the time.
  5. Okay, well I am guessing then that my video is progressive and not interlaced, because when I run it through a vdub deinterlace filter, the output video shows interlacing (that wasn't there to begin with).
  6. Member Cornucopia's Avatar
    That doesn't make sense.
    A "De-Interlacing" filter takes out the interlacing, not putting it back in.
    What you may be seeing are interline differences that would be smooth with an interlaced (or progressive) file, but which have been decimated to 1/2 the lines and will show twice the difference.
    Example:
    Original:
    AAAAAAAAAAAA
    AAAAAABBBBBB
    AAAABBBBBBBB
    AABBBBBBBBBB
    BBBBBBBBBBBB
    "De-Interlaced" using repetition:
    AAAAAAAAAAAA
    AAAAAAAAAAAA
    AAAABBBBBBBB
    AAAABBBBBBBB
    BBBBBBBBBBBB
    Why don't you post a screenshot of Before and After?...
  7. Cornucopia,
    I think you are right. I think that when I ran the file through the deinterlace filter, the result was lines that would have been smooth otherwise. I don't have any screen shots, sorry. But I do think you're right.
    Thanks!
