i want to extract specific audio samples/clips from movies and was wondering what is the best software approach
up until now i have simply recorded the analogue outs from a standard dvd player, but i would rather avoid the extra ad/da conversion (and avoid using spdif/adat)
one of my main issues is that i dont want to extract/import the entire movie or chapter clips...
...just specific parts be it 5 or 10 seconds or whatever
idealy i would like to be able to:
-extract only desired clips (in turn not having to extract the whole 2 hour movie audio file to get a 5 secnd clip)
-extract digital wav. files directly from the internal pc dvd rom drive.
-have the option of extracting from other formats like avi, divx, wmp, etc.
im using pc + motu + cubase sx2
tried DVD Audio Extractor? I think you can set start and stop to rip out short clips.
and if you are ripping from commercial dvds use anydvd in the background to remove encryption.
Software for extracting clips from DVD
By gaurav200x in forum EditingReplies: 2Last Post: 10th Aug 2010, 13:43 -
extracting just a audio clip from DVD and other video formats
By ted demen in forum Newbie / General discussionsReplies: 5Last Post: 9th Mar 2009, 17:03 -
Extracting audio from music DVD and burning to CD
By busterbrown885 in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 14:30 -
extracting clips
By turdburglar in forum MacReplies: 1Last Post: 15th Sep 2008, 06:29 -
Extracting movie audio from DVD
By CrystalDoll in forum AudioReplies: 6Last Post: 31st May 2007, 08:48
