    Jan 2006
    When I test my dvd on a tv, i hear some clicks, crackles and pops in the audio
    what can that be from?
    Is it possible my burner didn't burn the dvd well?
    do you hear the crackles if you play the burned dvd on your computer with a softwar dvd player?
    and how did you made the dvd? what is the video source and what software ?
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    How are you playing it back ? Is it through analogue leads to your TV, or through an optical digital connection to an amp ? Are you sure the noise is in the audio, and not the playback path ?
    Read my blog here.
    Jan 2006
    I'm going to test it again tonight when i'm home, but I have a feeling when i play the original mpg file on my pc it plays fine, but the DVD has the cracks and popples, i think it might be burner related (but is it likely?) i will try to burn the movie on another machine as well
    Jan 2006
    Just curious, is it possible the crackles and pops are from distorted sound or not likely?
    Jan 2006
    This was confirmed to be caused by my DVD Burner. I burned it onto another DVD, and everything was fine. Now the only thing i need to do is figure out how to burn the audio at a higher bitrate.
