When I open a video_ts folder in ffmpegX and I convert to avi (doing what the 'how to' from te site tells me to do), I only have an avi-file containing the first vob-file from the video_ts folder. How can I convert 6 vob-files in 1 avi-file?
thank you for helping me
Probably they are separate titles. Try to join them as indicated here, https://www.videohelp.com/forum/viewtopic.php?p=1056853#1056853
Thanks Major,
you wrote:
An unclean method to join files is the Unix "cat" command. It leaves header unchanged so issues may arise, but it can eventually work. The command to use in Terminal.app is the following (replace movie.vob to full path to your actual files, or drag and drop the files on the window to get their path).
cat movie1.vob movie2.vob movie3.vob > movie.vob
But what is terminal.app and where can I find this? Do you mean 'open' ?
Greetings
Video_TS to AVI
By aliasrobert999 in forum Video ConversionReplies: 1Last Post: 9th Mar 2011, 01:16 -
VIDEO_TS to .avi conversion help?
By itsjamesd in forum MacReplies: 4Last Post: 10th Nov 2010, 13:11 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 19:40 -
Video_TS to Avi encoding
By macbuz in forum MacReplies: 9Last Post: 16th Jan 2009, 14:59 -
convert VIDEO_TS to avi
By SeveralButchersApron in forum MacReplies: 14Last Post: 2nd Jun 2008, 19:50
