SolveigMM Video Splitter being AVI Splitter, WMV/ASF Splitter is a powerful tool to perform fast video trimming tasks without any quality loss. It has intuitive user-friendly interface and allows an user to split, cut or trim a video file in few mouse clicks. Based on SolveigMM AVI Trimmer Component, SolveigMM Video Splitter is very fast (much more than real-time playback) since it is free from encoding/decoding operations.
Solveig Multimedia is proud to introduce a new feature that makes video editing more comfortable and easy. Now it is possible to define fragments in video file, turn them on or off and render final video in one pass to cut off any movie portions.
Since ver. 1.2 batch files are supported! For now you can add all the trimming tasks to batch queue and process all of them in one pass.
SolveigMM Video Splitter features:
-Based on SolveigMM AVI Trimmer Component (COM object)
-Supports any AVI file format (DV type 1, 2, OpenDML) with any video (DivX, XviD, 3ivX, etc) and audio (MPEG L. 1,2,3, AC3, etc) content
-Supports WMV format
-Supports ASF file format with any video (WMV 1,2,3, MPEG-4 AVC, DivX, etc) and audio (MPEG L. 1,2,3, AC3, WMAudio V 2,7,8, etc) content
-AVI to ASF re-multiplexing (without re-encoding)
-Supports large AVI files (more than 2GB)
-Allows trimming AVI files contained VBR audio without synchronization loss
-Advanced K frame navigation
-K frame accuracy
-WYSIWYG (What You See Is What You Get ) preview
-Cutting off several file portions of a movie at one time is allowed. You can get rid of all commercials in your movie in a couple of simple steps.
-Supports bath files (*.xtl). You can edit all the files you need in one run
Fixes:
-The bug with Unicode file names e.g. with Chinese or Japanese symbols was fixed. Video Splitter was unable to open/same such files.
-The bug with opening/playing WMV files by Windows Media Player was fixed. After opening, WMP didn’t start playing of WMV files produced by Video Splitter.
-The ASF files produced by Beholder TV Tuner was fixed. Video Splitter was unable to edit ASF files (DivX + PCM) captured within Beholder TV Tuner.
-Some more bugs with WMV video/audio trimming precise were fixed
Features:
-Some Menu, Context Menu and Batch Manager changes were made for GUI simplification.
-"Menu->Output File Name.." was changed to "Save Media File As..". This menu point sets out file name and either starts trimming or add task to batch queue.
-"Context Menu->Save Selected Fragment As..." point was added. This point operates like "Menu->Output File Name.." but with one fragment only.
-"Invert Time Line Fragments" command automatically adds additional markers if it is necessary.
-For now you can switch off "Markers K Frame Positioning" and "Slider K Frame Positioning"
-Ignoring Trimming Errors" feature was added. (It's used when WM/ASF Reader delivers error "the buffer is not big enough").
-All the features including Task List (batch) file format is documented.
Regards,
Dmitry | SolveigMM | Smart Video Editing (H624/MPEG-2/...) -
SolveigMM Video Splitter v 1.2.7.31 beta update is available.
Zooming timeline slider In/Out feature was implemented.
How to splitte mkv Movie?
By kivawolf in forum EditingReplies: 2Last Post: 26th Sep 2011, 21:02 -
SolveigMM Video Splitter 2.2 Release. Files joining added
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 20th Apr 2010, 08:13 -
SolveigMM Video Spliter 2.1.901.23 Update
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 25th Jan 2009, 04:54 -
SolveigMM Video Splitter 2.1.810.30 Update
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 30th Oct 2008, 07:19 -
Ann: SolveigMM Video Editing SDK 1.0 released
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 23rd Jun 2007, 04:45
