I'm using PowerDVD and want to know how to capture a screenshot.
I've been told two things that don't work. One was use an icon on the player that looks like a camera, but this icon is not there. Also, I was told to press P and it should create a folder for it. This doesn't work, or I simply can't find the folder.
THANKS!
Results 1 to 9 of 9
Originally Posted by TooLFooL
*opens PowerDVD now to check*
Yep, you're right. Says so in the help:
Caution: This option will be unavailable if you enable video hardware acceleration. This option is found in the Video configuration under the section Hardware Acceleration. -
TO CAPTURE A SCREEN SHOT USING POWER DVD YOU NEED VERSION 5 OR HIGHER. PLAY THE DVD OR VCD OR SVCD IN POWER DVD AND WHEN THE SCREEN COMES UP THAT YOU WANT TO CAPTURE I USUALLY PAUSE THE SCREEN AND THEN CLICK ON THE CAMERA ICON. THAT WAY YOU GET A CLEAN SAVE WITH NO BLUR. LBJOHNSON
Lawrence Johnson -
You should be able to use a screen capture application that can capture DirectX overlay surfaces.
Creative Softworx, Inc.
Makers of Capture Professional Windows screen capture software
2001-2010 my capture cards - comparison screenshots
By Brad in forum Capturing and VCRReplies: 34Last Post: 15th May 2013, 02:06 -
Ati All In Wonder HD and PS3 screenshots and capture HD video.. help needed
By C.P in forum Capturing and VCRReplies: 6Last Post: 30th Mar 2010, 17:46 -
mp4 capture appears distorted. Fine in quicktime. Screenshots on post
By flamy in forum Video ConversionReplies: 17Last Post: 29th Mar 2010, 11:22 -
Screenshots index like this one, how can I do this?
By miraniec in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2009, 20:26 -
How do I capture screenshots of my xbox 360 with a Neoya x2vga?
By travb in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 08:34
