I've been reading that aac re-produces results closer to the original mix.
Is there a huge benefit to using aac for video?
does an equal bit rate in mp3 or aac equal the same file size?
And finally what do you need to encode aac?
I currently use goldwav and razerlame..
You might look here for a comparison of ACC VS MP3 quality and filesize: http://en.wikipedia.org/wiki/Advanced_Audio_Coding
Looks like Nero Digital Audio can do it, and possibly BeSweet with the Belight GUI. Probably others, also. -
SUPER does a great job if you want both video AVC (Advanced Video Codec) and AAC in the same file. Or Quicktime Pro if you're willing to pay the $30.
AAC does produce better quality audio at smaller filesize ratios. It's simply the next technology after MP3. The same as AVC (h.264) is the next technology after divx video (and partially based on it).-Tevya
Start WordPress
AAC and mp3 into mp4 - my mp4boxgui error
By peaceDOThuxDOTde in forum Video ConversionReplies: 0Last Post: 10th Jan 2012, 07:15 -
Found freeware AAC to mp3 converter
By jimdagys in forum AudioReplies: 14Last Post: 22nd Aug 2010, 17:18 -
AAC to MP3
By anirban in forum AudioReplies: 1Last Post: 5th Dec 2008, 12:09 -
AAC 5.1 to WAV or MP3
By Tres_Sol in forum AudioReplies: 1Last Post: 2nd Sep 2008, 22:05 -
Changing an AAC file to an MP3...?
By darkzero297 in forum AudioReplies: 5Last Post: 4th May 2007, 05:54
