  1. Can i record an svcd sturctured and formatted mpeg stream onto a DVD media or will it not be accepted or will the burning device ask for a Cd ???
    Can i record mp3 audio onto a DVD media and expect it to play in my DVD player which supports mp3 audio playback
    USA
    Not really. You may be able to make a hybrid DVD or a DVD-SVCD by using this method: https://www.videohelp.com/svcddvdr.htm
    But I use ConvertXToDVD to convert my SVCD's to DVD. A program made just for that purpose is SVCD2DVD.
    Besides the video arrangement being different on a SVCD, the audio is 44kHz and that needs to be converted to 48KHz for the DVD standard. You can see the DVD standards to the upper left in 'What is' DVD. <<<<<<<
    For MP3 audio, it is not part of the DVD format. You can burn it as a DVD data disc and if your player can accept that, should work fine.
    And please, in the future, use a post title that reflects your subject. 'Just 2 questions' gives no indication of your subject and makes this thread impossible to search for. Please read our rules and change your title.
    Moderator redwudz
    Aug 2003
    Texas
    I second the use of SVCD2DVD. It's a great little All-In-One program for converting, authoring &
    burning SVCD, AVI & .BIN files as DVD. Of course, many players will play the raw SVCD and AVI files either on CD or DVD.
    I can play MP3s from DVD just fine in my Philips 642.
    Be adventureous! Make a test disk on DVD-RW and see what you can do.
  4. Originally Posted by perfection
    Yes, you can do both, burning a data DVD.
    Apr 2006
    Brazil
    I use NERO 6 to do both with very good result.
    Buy yourself SVCD2DVD.
    It's an excellent piece of DVD authoring software, and it accepts non-standard MPEG files for authoring. Unlike other methods that exist, this one is very affordable, very easy to use, and has some qualities only found in high-end software.
    Trial available, to give a test drive.
    Nero re-encodes, bad idea. Data DVD is not going to play in a DVD player.
