    Aug 2003
    los angeles
    go dvdplayer d640 that worked perfectly before and was put away for several months now with any dvd media inserted(even store bought movies) tray will k keep opening and closing.
    go video support never answered , and i seee no firmware updates. any iddeas? thanks
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Most often, it the door won't stay closed, it is a bad sensor. It could most likely be fixed fairly cheaply ($35-50), but a new player likely wouldn't cost much more.
    Google is your Friend
