After numerous problems with other dvd authoring software I stumbled on ConvertXToDVD and it is great. I converted a 45min tv episode to dvd format in under 25mins,best I have got from any program. Now because of this speed I could easily make 2 or 3 dvd's overnight while I sleep
. Does anyone know if this is possible, and if so how?
Not possible. You can't even run multiple instances of ConvertXtoDVD at the same time.
However, you can set a custom size in mbs. Theoretically, you could create a huge DVD, then author from the converted video later to make smaller discs.Read my blog here.
Avisynth batch scripter run-time error 380
By dude112 in forum Video ConversionReplies: 4Last Post: 13th Oct 2010, 13:13 -
Can I batch convert with convertXtoDVD?
By coopgang in forum Video ConversionReplies: 10Last Post: 23rd Jun 2010, 07:15 -
Batch Convertxtodvd
By jack1993 in forum Authoring (DVD)Replies: 6Last Post: 18th Oct 2009, 23:28 -
Batch processing of multiple projects...
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Sep 2008, 08:31 -
Need some help with ConvertXtoDVD and using a batch file...
By DVDNewb in forum Newbie / General discussionsReplies: 3Last Post: 9th Jan 2008, 17:45
