hey everyone,
under the "de-interlace" filter there are bunches of options. i know that blend (adaptive) gives the best results and so far worked perfectly. however, for some reason, the last two rips i used with it, the interlaced lines weren't removed. i was told blend (animation) was the one that doesn't seem to work all the time. i assumed blend (adaptive) was basically the same as blend...but just that the CPU analyzes the movie and uses blend when needed. blend (adaptive) has worked to get rid of those pesky lines during scene changes (which are barely noticeable in the first place)...however, the last 2 dvd rips i used it on, blend (adaptive) wasn't able to get rid of the lines. was it cuz the last 2 dvd rips have a lot more scenes with lines in it?....however, i've used blend (adaptive) to remove lines from pure NTSC dvds before and all the lines were removed (but jumpy as hell), so i dunno wut happened with the last 2 rips. help?
o yea..and i almost forgot..anyone else have the same prob as me with blend (adaptive) not removing all the lines?
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 4th Aug 2009, 23:55 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
SmallDVD doesn't work
By dnix71 in forum MacReplies: 10Last Post: 29th Aug 2007, 00:47 -
Newbie: Why doesn't it work?
By orchestr in forum ffmpegX general discussionReplies: 8Last Post: 24th May 2007, 11:30
