Hi
Hi have a video mpg file and a audio wav file that I want to multiplex in to 1 new mpg file
I use the mpgtools of tmpgenc in the simple multiplex tab i add my video file and when i had my audio wav file I have this error message
Multiplexing linear pcm stream is not supported
Can anyone tell me why and how can i solve this issue
I normally use wav file as the audio source when converting and it work fine
thanx
I don't think you understood Baldrick. Let me put it another way...
You want to make a DVD.
DVDs' media is made up of VOB files.
VOB files are like a "Super" MPEG2 program stream (in that they can have ADDITIONAL material that normally isn't allowed in MPEG2 program streams -- like LPCM audio, subtitles, text, NAVIGATION data)
You want to multiplex (mux) a video stream (m2v) with an audio stream ("wav").
WAV is (by default) an LPCM audio stream with headers/wrappers tacked on.
You're trying to mux them into a STANDARD mpeg2 program stream.
Won't work.
With ANY standard MPEG2 program stream muxer.
You really want to mux them into a VOB file.
You can easily do that--BY AUTHORING A DVD. The authoring software incorporates a VOB muxer. That's the only way you can mux to a vob.
I think you might be worried that you can't use the separate elementary (audio & video) streams as sources without muxing them first. Don't worry. Hardly any authoring app has this requirement--most happily accept separate streams. Those that don't are hopelessly "newbie" in orientation, IMHO. Meaning they probably only let you use MP2 as audio anyway, which isnt' the most compliant for NTSC users...
OTOH, AC3 and MP2 audio can be pre-muxed into a MPEG2 Program stream, with standard muxers like TMPGEnc.
Those are the 3 formats you should be working with (could do DTS--but you have to walk before you can run, and you'd have to have one of the others as 1st stream anyway).
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 02:54
