How can I tell a menu to wait until the background video is over to play the selected tuttle?
thx
Which authoring program are you using?
He's a liar and a murderer, and I say that with all due respect. -
I think you can edit the xml file and set Wait to match exactly the audio duration
No need to edit the xml. Simply click the 'timer' icon in the menu editor. Select which title you want to play after the menu ends.
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:00 -
More than 12 buttons with dvdauthor
By PeskyJ in forum Authoring (DVD)Replies: 7Last Post: 17th Dec 2008, 17:50 -
Question about auto jump to next title with Gui For DVDAuthor
By jimdagys in forum Authoring (DVD)Replies: 6Last Post: 26th Nov 2008, 03:55 -
GUI for DVDAuthor
By netbuddy in forum Authoring (DVD)Replies: 35Last Post: 15th Nov 2007, 06:12 -
GUI for DVDAuthor Question
By tygger in forum Authoring (DVD)Replies: 1Last Post: 22nd Jun 2007, 23:24
