how do you do it?
I read somewhere that you need a converter that links up to the computer through the IEEE1394 cable.
Can you do it, however through the RCA jacks? Plug the RCA jacks in the camera and hook it up to the tv. Insert the tape in the vcr, let it play and the press record on the digital camcorder.
Would this work also?
How's My English?
If the RCA jacks are inputs, then the answer is yes. You could also hook the VCR directly to the camera through RCA inputs, then transfer to the PC through the cable.
If the RCA jacks are outputs (watch the tape in the camera on TV) then the asnwer is no.Even a broken clock is right twice a day. -
If you are transferring to the computer through the DV port, WinDV will work. Once you get it on the computer, most AVI video editors will work. You may need to install a DV codec for some. The Panasonic DV codec is one of them.
You can also use VirtualDub to edit. All these are freeware.
If you have Vegas, give it a try. At least the newest version can do DV transfers.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
