tscv motion menu guide
regarding the first part of the tutorial
"you will also need vfapi v103b" got that.
10.add job
11.click on all files (this space is totally blank)
12.open the mpg that you have encoded (an error comes up)
what am i doing wrong?
I,ve sorta fixed the problem but not because i can create the .avi file with vfapi but when i go into the menu tab in tscv and clicker on add mpg and then add the vfapi-avi i created i get error "MMSYSTEM006 There is no driver installed on your system" but.......
if i just cliker on add mpeg and the click cancel when the vfapi-avi open dialog comes up the mpg loads up fine and there is no error. Has anyone had this problem? Am I posting in the wrong thread? -
No you are not alone!
I have also had this problem. Were you able to make menus with your chapter entry points you created?
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Creating buttons on a motion menu
By jrd3263 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2008, 16:13 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
GFD motion menu stuttering
By spamiaint in forum Authoring (DVD)Replies: 2Last Post: 15th May 2008, 09:58
