What advantages it makes using AC3 sound while DVD Authoring comparing with PCM or MPEG audio. Is it only the smaller output audio size or it is better quality.
Regards.
QUALITY HAS A NAME
As far as I can tell dolby digital ac3 stereo is SIMILAR in size to mpeg audio at the same bitrate. BUT ac3 is capable of digital surround sound whereas mpeg surround sound is either not possible or not as commonly supported.
Yes smaller file sizes at comparable audio quality are the main reason to use ac3 or mpeg audio. If you want to up the video bitrate but maintain audio quality use one of the two compressed audio formats.
If you have a relatively short video and you want to maintain highest audio quality then use pcm to preserve the quality. But the longer the video is the more you will want to use compressed audio.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
well of course, same bitrate=same sizeOriginally Posted by yoda313Sorry, I had to go see about a girl
advantages of transcoding mpeg2
By codemaster in forum EditingReplies: 4Last Post: 26th Apr 2012, 17:11 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
What advantages are there in using .MP4 over .MKV if any
By Onceler2 in forum Video ConversionReplies: 2Last Post: 26th Jul 2011, 16:53 -
Advantages of ISO?
By hardy in forum Newbie / General discussionsReplies: 6Last Post: 27th Sep 2010, 18:42 -
Analog TV-Monitor Advantages?
By therock003 in forum Newbie / General discussionsReplies: 37Last Post: 27th Jan 2009, 17:57
